2004 Expedition knocking sound
there is a very ANNOYING knocking sound going on in the back passenger area. It started last night, and happens the ENTIRE time I'm driving. It is coming from the back panel area, as you can really hear it when you put your ear up to that area. anybody know what it is, or how to get rid of it? Thanks!
I have a 2004 also and ours had a knock at aprox 2 to 3 second intervals when running the rear A/C - heater fan? It turned out to be some environmental component (not sure what it is yet) on the inside RH side the vehicle between the 2nd and 3rd row seat (above and slightly fwd of right rear tire). I simply pulled up an interior panel and felt what item was clicking and simply unplugged it. Everything is working normal with the A/C and heat. I will investigate what the item does and repair it once the weather gets a bit better.
Faulty coils causing knocking
Had a very similar and recurring issue.
Traced the knocking to the sub-woofer. The knocking was some electrical feedback coming from one, or more, faulty coils. The coil(s) were failing, but not enough to register a code, or cause any perfromance issues.
I am STILL having coil issues. Anyone install aftermarket coils and with better results? I replaced with ACCER and am considering trying Weapon X.
Dave
Dave
