ABS light and braking to the right
98 Expedition EB, 2whdr - brake failure when wheels turned to right at slow speed. New pads, rotors and bearings.... did not fix the problem. Brakes OK while driving, yet pull into a parking spot... and brake failure. Brake booster seems to be holding pressure... what else can i try ..? help
usually if a vehicle pulls to one side or the other it means that only one side is getting pressure to the caliper on that side causing the vehicle to pull to that side. it also means that there could air in the lines and really needs to bled off. or the speed sensor may have failed. was the weather good when it happened or ice been where you parked?
aangel
01-16-2009 03:01 PM
rodav8
07-02-2007 11:41 AM
