Expedition Dies At Start Up - Ford Forum - Enthusiast Forums for Ford Owners
LinkBack Thread Tools Search this Thread
Old 04-06-2005, 12:24 AM
Default Expedition Dies At Start Up
I have a 1999 Expedition that has started intermitently dying after it starts. RPM's go up for the start, then it just flat dies. I can keep the motor running when applying pressure to the gas peddle, but as soon as you remove your foot, it dies. Please help.
Old 04-08-2005, 04:13 PM
Default RE: Expedition Dies At Start Up
Check the idle controll motor
Old 06-04-2005, 02:11 AM
Put gas in it.. replace plugs and wires. Check for broken pcv tubes on the motor near the top rear (passenger side of motor.) Replace pcv and fuel filter. Take it to the shop and have it tested after you replace those items to make sure there was no permanent damage to the motor. Like this one guy said.. your car only needs air gas and fire to make it run but it has to run right to drive it.
Old 03-22-2006, 02:59 PM
Sounds like the Idle Control Valve near the firewall (center of firewall) in the engine compartment, on top of the engine. Mine did the same thing and it costs about $50.00 from NAPA for the part. The part is not in the easiest place to get to but can be changed out if you have a socket wrench or open ended wrench.
Old 12-10-2006, 12:49 PM
Quote:
ORIGINAL: ejw67251
Idle Air control Valve- period. 40 bucks- you're back in business. Top of intake manifold, center of the engine, almost touching the firewall in the back. Not the easiest to get to, but you can swing it. Two bolts and a gasket- that's it.
Thread Thread Starter Forum Replies Last Post
06 6.0 dies after it gets hot wont start until it cools j1004ss Ford F-250 & Ford F-350 0 07-15-2015 03:05 PM
1992 5.8L mystery start then dies cjlopr General Tech 2 12-03-2012 02:32 PM
88 ford 5.0L Starts,dies,starts,dies snapper1d General Tech 4 12-10-2010 10:26 AM
2002 Sable 3.0, if you start with AC on it dies. kube_1989 Ford Taurus 1 08-10-2009 11:41 AM
Expedition dies when cold... kccollier Ford Expedition 3 03-06-2006 05:51 PM
Tags
2000, 2006, 97, 99, control, die, dies, expedition, ford, idle, idling, module, roach5337, start, starts
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
