info center issue
Old 04-07-2009, 08:07 AM
rnemtb's Avatar
Default info center issue
good morning,
i have a 99 expedition Eddie Bauer with info center in overhead console. the center has estimated mileage before next fill up and direction vehicle is traveling (ie:north ,south, east ,etc). the direction traveling indicator is showing the wrong direction,is there a way to reset it or do i need to replace a module? i have not disconnected the battery yet.
any help is greatly appreciated.
George Capraun
Old 04-07-2009, 11:32 AM
Try a compass calibration..
Calibration Adjustment..
For optimum calibration, turn off all non-essential electrical accessories (rear window defrost, heater/air conditioning, map lamps, wipers, etc.) and make sure all doors are shut.
Drive to an open, level area away from large metallic objects or structures and high voltage lines.
Insert an appropriate-diameter rod, preferably non-metallic, into the switch access hole underneath the compass module. Press gently for two to four seconds until 'CAL' and a direction are displayed.
Release the switch and drive slowly in a circle until 'CAL' disappears from the display (about two to three circles).
The compass is now calibrated.
Old 04-07-2009, 01:04 PM
rnemtb's Avatar
thanks will give this a try.
Old 04-22-2009, 03:05 PM
rnemtb's Avatar
tried the calibration instructions . no luck ,guessing the module is bad.
thanks for the advice.
smith42c
01-25-2012 04:00 AM
fosno1
05-19-2006 03:12 AM
explorerman
04-12-2006 11:20 PM
doc99
10-15-2005 11:18 PM
roguespirit
09-28-2005 07:17 PM
Quick Reply: info center issue
