gas cap
Old 01-08-2008, 04:18 PM
ups54's Avatar
Default gas cap
I have a 2002 Sport Trac that has check gas cap lite on. I replaced cap with new one from Ford and lite still on. Is there anything else I can check before I have to go to Ford and spend $160 for them to figure it out?
Old 01-08-2008, 08:25 PM
Default RE: gas cap
You will have to clear the code before the light will code out.
Old 01-09-2008, 12:44 AM
Default RE: gas cap
try disconnect battery to clear fault indicator, then re hook battery that might do it.
Old 01-09-2008, 03:27 PM
oldtimer35's Avatar
Default RE: gas cap
Actually, the gas cap lite is set because the system sees a failure in the evaporative emission system. The is a problem with the vapor recovery system, possibly a leak, and it is large enough that when the vehicle runs a test, it sees this large leak. Now is you have just replaced your cap, it will take two drive cylces for it to reset the light. Don't ask what a drive cylce is, but it might take you a week of driving to complete one. So, if your trying to avoid paying $160 to find out, drive it to see if the cap was the problem. I can't understand why a deal would charge you that much because a smoke test on the system should run you about $80. where I work.
Old 01-10-2008, 11:07 AM
ups54's Avatar
Default RE: gas cap
Thanks guys. I disconnected battery and lite out now. I don't know why Ford wants $160 either. I think thats pretty steep. Thanks again.
Old 01-10-2008, 06:31 PM
Default RE: gas cap
no problem, u know there are 2 ford forums???
Old 01-10-2008, 06:32 PM
CADenny
07-31-2008 10:24 AM
mikegigabyte
02-29-2008 08:25 AM
loomisgang
08-28-2007 04:05 PM
CharlesC
01-21-2007 11:44 PM
reggi05
01-28-2006 09:03 PM
Quick Reply: gas cap
