2002 explorer will not start electrical?
Old 05-07-2005, 01:59 AM
russ124's Avatar
Default 2002 explorer will not start electrical?
I have a 2002 v6 explorer xlt 4wd. Today the vehicle suddenly would not start. I was getting wild variations on the instrument gauges but the starter would just click. I managed to jump it off once and get it home. I went through all the relays and fuses in the pdb and fuse block and they check out fine. I purchased a new battery and the vehicle will now turn over but I have no fuel pump, gauges, seats will not work and the interior light is out. I rechecked the fuses and relays and they appear to be fine. Any suggestions?
Russ
Old 05-09-2005, 04:54 PM
Default RE: 2002 explorer will not start electrical?
Check for fusible links at the starter solenoid
Old 06-03-2005, 03:22 AM
HOW ARE YOU CHECKING THE FUSES, JUST LOOKING AT THEM, IF SO, GET A TEST LIGHT TO VERIFY POWER AT BATTERY JUNTION BOX. TRY TO INCLUDE MORE INFO ABOUT HOW YOU TEST SO I CAN HELP YOU MORE, QUESTIONS, JUST REPLY.
Old 09-03-2008, 03:15 PM
i am having the same problem right now can someone tell me what the original solution was in 05 for the no start problem
Old 09-03-2008, 03:31 PM
Exact same symptoms? Same application ect.. The more specific info you can give, can/will providea better result for a fix...
Old 09-03-2008, 03:56 PM
was taking my son back to college sat got home sun night no problem. my wife took the truck mon morning for coffee and back no problem. we went to the mall outlets 20 miles from our house no problem. on the way home we stopped for fule . i shut the truck off fueled up and when i went to start the truck the gauges and dash lights went crazy and only clicking. had it towed home and that night i tried jumping it and it started i let it runb for 20 min then shut it off. went to start it and exact same problem
Old 09-03-2008, 04:04 PM
crazy stuff ive never seen anything like this
Old 09-03-2008, 04:11 PM
any suggestions????
Old 09-03-2008, 04:14 PM
2002 explorer xlt 6cyl 4wheel dr
Old 11-01-2008, 12:00 AM
raj828's Avatar
i also did have that problem just tonight, luckily i was at the mall where there was a security car to jump start my explorer ('04). i arrived home, turn off the engine and it won't start. but tried to start it again it just won't crank....the lights were faint, no gauges... but it would come back after awhile... i saw my battery was still ok(free maintenance battery)
any suggestions?
thanks...
Quick Reply: 2002 explorer will not start electrical?
