HELP, PLEASE
Old 10-06-2007, 05:50 PM
fisherman's Avatar
Default HELP, PLEASE
Am working on a '91 Explorer and have discovered gasoline in the oil. Can anyone tell me why or how this could have happened?
Any help is greatly appreciated!
Robin
Old 10-06-2007, 10:27 PM
Tony R's Avatar
Default RE: HELP, PLEASE
when you drive your car is it getting up to opperating temp? If you are only taking it for short drives and it stays coldyour engines rings dont work properly and you will get fuel seepage into your crank case. It is a more common problem on the V8s and 6s than on the smaller engines.
Old 10-16-2007, 07:29 PM
comming from the intake probably thru the carb or manifold area..check carb? for sticking float if carbutated..
LakelandF150
03-25-2012 08:57 PM
llazarus10
03-07-2011 05:33 PM
Adhd
02-03-2008 09:55 PM
davequest
09-12-2006 04:16 AM
Quick Reply: HELP, PLEASE
