2006 Ford Explore Making chirping noise when on the gas pedal
Hey I just recently purchased a 06 Ford Explorer. It is making a weird chirping noise while I'm driving. I notice that the noise will only occur when pressing the gas pedal. I know there's probably previous thread about it. Please help me out by pointing me to the right thread or any solutions about this? I've done a little googling and have found that it may be the cramshaft sensor? How can I test this? The noise doesn't seem to occur while the car is parked or idle. Also the noise disappear when I let go of the gas. Should I just return the car? Or is this something I can reasonably fix?
2006 V6
rear end drive
2006 V6
rear end drive
Not to give you additional cause for concern, but timing components can cause similar sounding problems. If that is involved , why not get an authentic diagnosis and the cost involve to correct , then consider your options ?
