2007 explorer v6 4.0L IAC valve
Old 02-24-2017, 07:18 AM
tipenzo's Avatar
Default 2007 explorer v6 4.0L IAC valve
would anyone know where the IAC valve is located on this engine, i cant seem to find it. 2007 v6 4.0L Also the Schrader valve to test the fuel system pressure is not on the fuel rail.- thanks
Old 02-24-2017, 12:08 PM
There is no IAC with an electronic throttle body and the fuel pressure is read from a fuel pressure sensor with a scan tool.
You might try cleaning the air inlet of the throttle body with the special cleaner, BUT, do not attempt to move the throttle butterfly . That will destroy the inner workings of the electronic throttle body.
Old 02-24-2017, 02:38 PM
tipenzo's Avatar
thank you hanky.
the problem i am chasing is a hard starting condition the engine stumbles then dies it takes about 4 to 5 turns on the ignition and then it remains running. i went ahead and disconnected the throttle body and cleaned it out with throttle cleaner and a toothbrush i found it pretty dirty with caked on oil and soot upon doing this the problem seems almost 70% better but however it stills does it 3 out of 8 starts. so now i see no iac valve thank you for the info. i was hoping to find a bad iac valve but i guess not. the other thing is the pcv valve do you know where the pcv valve may be? im lost i cant test the fuel pressure because i also do not see a schrader valve to hook up to.
thanks
Old 02-24-2017, 02:39 PM
tipenzo's Avatar
and i do not have a scan tool available
Old 02-24-2017, 04:57 PM
Many auto supply stores will check your vehicle for codes and pending codes free of charge. It's always a good place to start. If it does have any codes let us know the code(s) or you can look them up on line .Can you do this?
Old 02-24-2017, 05:44 PM
tipenzo's Avatar
thank you hanky but there is no check engine light on no codes
Old 02-25-2017, 07:27 AM
Something you can try,
Before turning the key to the start position,
Turn the key from off to on 3-4 times then attempt to start the vehicle, if it start easily there may be a problem with the fuel pump check valve.
Before going any further , what result do you get?
thefrog
03-14-2016 07:47 PM
Welderguy
03-14-2016 07:39 PM
Hemionus
09-16-2013 03:19 PM
Mike Hickman
07-04-2007 05:29 PM
kevhed
01-16-2007 01:06 PM
Quick Reply: 2007 explorer v6 4.0L IAC valve
