p0171 code
Old 09-15-2005, 02:14 AM
macnisas's Avatar
Default p0171 code
My 1999 explorer is registering a fault code p0171( system too lean (bank #1). Any help in what this means would be appreciated.
Old 09-15-2005, 06:54 PM
Default RE: p0171 code
If you have the scaner, let us know what the voltage of O2 sensor1 bank1 is.
Old 09-17-2005, 01:35 PM
there is a tsb on that code for reprogramming the pcm i worked on one the other day reprogrammed and ok
Old 09-18-2005, 05:15 AM
macnisas's Avatar
Run test and erased code, no problems as of yet. Will be back to ask advice if problem returns. Thank you for responses thus far.
Old 09-29-2005, 04:01 AM
jbwilli's Avatar
#1 fuel injector is clogging. Check electrical physical connection to #1 nozzle. If no help, try a fuel injectore cleaner gas additive. If still no help, change the injector.
If your have TBI, all of this is will not work!
Old 09-29-2005, 08:01 PM
why would you say number one injector is the problem ,is bank one not number one and i have at a ford dealer for 5 years and not seen or heard of that one and i am not talking about the code lol
Old 11-05-2005, 01:29 PM
jbwilli's Avatar
You are exactly correct!? I was answering a question on #1 fuel injector fault. I don't know how it ended up here???
diehardgator1
12-11-2013 07:21 PM
cjohnston2
12-22-2012 11:11 AM
orangeranger2000
05-25-2010 09:42 PM
argneco
03-25-2009 06:04 PM
rmd8123
01-08-2009 03:18 AM
Quick Reply: p0171 code
