92 eddie speed o. jumps around
Old 01-30-2006, 01:11 AM
j.c.'s Avatar
Default 92 eddie speed o. jumps around
MY SPEED O. JUMPS UP AND DOWN ANY SPEED 5 MI. UP 5 MI. DOWN BACK IN FORTH ALL THE TIME PLEASE HELP.
Old 02-07-2006, 11:49 PM
Default RE: 92 eddie speed o. jumps around
I just realised that Ive been getting that to on my 93. It happens around the 45-50 mph mark then when I go lower it stops. idk how to fix it but if u find out tell me
Old 02-08-2006, 01:15 AM
j.c.'s Avatar
hey smoke how many miles do you have on your truck i have 161,000 on mine this may be the problem
Old 02-08-2006, 08:47 AM
I got well the OD says 52 thousand something but I know there's more probably 100-200 thousand. It usually happens when its windy out so thats what I balme it on.
Old 12-08-2016, 08:27 PM
NRGNUKE's Avatar
it should be in the sensor in your rear-end that causes that. I had some serious problems with that and the PSOM on my 94 f150 XLT 4x4. Mine was in the PSOM as it told the ecm to shift at weird times and such. But if you change your sensor, likely you will be fine. Been a while, but I am pretty sure that was the problem with the jumpy speedo problem. could also be a loose connection too.
Old 05-05-2017, 01:35 AM
AA7KN's Avatar
Default Check this out
next time you are under your explorer, drop the skid pan under the transmission and on tio of the transfer case toward the back is the VSS ( vehicle speed sensor) unplug the connector and remover the hold down bolt, and work out the sensor. it is gear driven for your year and get a new one. the new one comes without a gear so just remove the clip and gear from your old one and put it on the new one and install it and your speedo should stop bouncing all over the place. Hope this helps.
newfy
09-09-2010 09:27 AM
whitty
01-02-2009 08:40 PM
superdavefarmer
02-22-2008 08:50 PM
abaca
04-18-2005 03:05 AM
Quick Reply: 92 eddie speed o. jumps around
