95 Explorer no power to fuel pump
Old 07-23-2008, 10:15 PM
IneedHelp's Avatar
Default 95 Explorer no power to fuel pump
1995 Explorer was runing fine, Stop at B.K. for a bite, went to start it up again and all it would do is crankbut not start. So I towed it home and switch around some of the relays still no power. any ideas? it my only car. Thanks
Old 07-24-2008, 07:17 AM
Default RE: 95 Explorer no power to fuel pump
Try resetting your (I don't know what it's really called but if you get bumped it shuts off the fuel pump) part. It's usually located in the passenger side kick panel. Check all your fuses too.
Old 07-24-2008, 09:03 AM
Have you checked the fuel pump reset button? The reset button should be in the back of the truck, usually inside. If you cant find look at your manual. Ronbo
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
Spaznaut
05-24-2014 02:10 PM
Timbo
04-18-2013 11:39 AM
IneedHelp
07-23-2008 10:15 PM
Quick Reply: 95 Explorer no power to fuel pump
