ALTERNATOR--2000 Explorer 4.0L V6 SOHC
The motor and chassis have been used for the donor for another another body and everything works but the alternator isn't charging. how do i rewire the alternator to get this thing charging?
I am having trouble with the charging system on our 2000 explorer as well, the first problem started when i had to replace the gear shift rod in the column, shortly after that the Alternator would not charge the battery, I've replaced the alt 3 times and the battery 2 times,I've checked all the fuses, traced all the wires, I am stumped!It will hold a charge after using a battery charger as long as the vehicle is not running!
mine got fixed by changing two wires that come off the alternator. The big wire stayed the same but the three wire harness got off and one of the wires was not used one was connected to 12 volts and one was connected to 4 ohms. Fixed by a guy in Boise.
bluzzer
12-13-2018 08:56 AM
