2004 Limited AWD V8: Towing capacity
Old 04-16-2007, 04:43 PM
pt575's Avatar
Default 2004 Limited AWD V8: Towing capacity
Anyone know the towing capacity on this vehicle? I've got the 4.6L V8 AWD with the Class III/IV towing package. The owner's manual has me thoroughly confused (it says the 4X2 can tow more than either the 4X4 or AWD and I'm wondering if that is some kind of printing error) and I can't read the label on the door. I've heard anywhere from 5500-7500 pounds, but then the manual says only like 3,500 pounds.
Anyone know the correct weight? Thanks!
Old 04-18-2007, 05:59 PM
Default RE: 2004 Limited AWD V8: Towing capacity
I would call a dealership if i were you just to make sure you get the correct information about this question. With it being a 2004 there should be plenty of people at a dealership with info on hand.
Old 04-19-2007, 11:48 AM
Use Common Sense's Avatar
Don't have a manual to refre to but, the max towing capacity whenproperly equipped should be as follows.
V-6 4x2: 5780
V-6 4x4: 5380
V-6 AWD: 5380
V-8 4x2: 7140
V-8 4x4: 7000
V-8 AWD: 7000
It is normally based on engine size, drive type and gears. A 4x2 will always have a higher tow capacity as the engine and tranny doesn't have to turn the front drive assemblies and carry the additional drive assembly weight.
Old 04-19-2007, 02:41 PM
pt575's Avatar
Thanks for the info. Got a boat to tow that is 5500 lb "wet" and wanted to make sure I was OK.
Jason Smith
07-23-2013 10:42 AM
pt575
10-05-2007 06:31 PM
yorttroy
01-03-2006 07:18 PM
rhennosy
09-26-2005 02:55 PM
sprig
07-18-2005 09:16 PM
Quick Reply: 2004 Limited AWD V8: Towing capacity
