Body Replacement Parts
Old 02-25-2007, 09:43 PM
01ExplorerSport's Avatar
Default Body Replacement Parts
Anyone know where I can get access to body trim or any/all other types of replacement parts for a 2001 Explorer Sport online?? I would rather not have to deal with a dealership about getting new replacement parts, but I guess I will if there is really no other option.
Old 02-25-2007, 11:06 PM
Default RE: Body Replacement Parts
Rebuilding a wreck?
Trim pieces usually aren't available aftermarket, sheet metal, lighting, brite work, structural pieces are.. What parts do you need?
Old 02-25-2007, 11:53 PM
The molding on the base of both doors is coming loose and look like they are about to fall off. Also the back bumper is starting to chip paint, but I think I can find a replacement rear bumper. It's the molding that I have been unsuccessful finding.
Old 02-27-2007, 04:02 AM
goinstrong's Avatar
Ford.com might have them - or go to an online search engine like looksmart.com and type in what you need in three or four words or less and it should show you a whole list of online retailers. Have you tried calling around to local salvage yards? If the tape on the back of them coming loose is the only problem - a body shop shouldn't charge too much to replace just the tape OR you could go to a paint and body parts retailer and buy the double-sided trim adhesive tape and cut off the old stuff yourself (takes a while) and replace it (just be sure not to pull off the paint with the old trim tape- it must be carefully cut loose and when you put the new stuff on make sure you have it clean and lined up straight the first time. Good luck.
WV-F150-4.2L
03-16-2011 06:34 PM
PCguru1024
04-01-2007 08:58 PM
whoyourdaddy49
02-11-2007 07:45 PM
sjbboy38
01-09-2007 03:24 PM
josser
01-16-2006 12:49 AM
Quick Reply: Body Replacement Parts
