Does computer have anything to do with the transmission
Old 07-03-2015, 04:37 PM
Bobp30nc's Avatar
Default Does computer have anything to do with the transmission
Have a 99 explorer, have had problems with it running. Put a new computer in it and now the transmission will act like it is not in gear or comes out of gear while driving....HELP.
Old 07-04-2015, 10:26 AM
primem's Avatar
The short answer is yes; the tcm/pcm governs the transmission operation. It may or may not be the cause of your trans problem. You may have a hard part failure that is nothing to do with the module. More information is needed.
which module did you replace? Did you install a new or used module? Was it installed by a dealer or yourself? Was it programmed before installation. Why exactly did the module need replacement? How soon after replacement did the trans problem occur? Modules have shift adapts....putting a different module into a old transmission without resetting the shift adapts would cause harsh shifts for the first couple days until the trans adjusts the shift timing.
I would check for dtc first as a starting point.
Your problem description is vague. So you put it in gear and you have no forward or rearward movement? Is the trans slipping? Elaborate.
MorePowerTuning
04-19-2015 10:12 AM
Michelle Phillips
01-17-2013 05:20 PM
77monarch
01-26-2011 12:40 PM
Gregski
04-29-2010 02:14 AM
royalty
07-04-2007 12:16 AM
Quick Reply: Does computer have anything to do with the transmission
