ODB II Code 174 only
Old 01-09-2008, 07:06 PM
exp97's Avatar
Default ODB II Code 174 only
On my 1997 Explorer XLT, the only code I am able to read is:
0174 System Too Lean (Bank 2). I've seen many postings that include 0174 but they usually seem to state both 0171 and 0174 System Too Lean for Banks 1 and 2.
With only one bank showing this error is it a safe bet that the issue is with the oxygen sensor related to bank 2?
If this is an incorrect assumption, then I would appreciate hearing what other possible causes would only produce this one code, and in what order it makes sense for a do-it-yourselfer to tackle them based on cost and also ease of task. Thanks for any advice anyone can offer!![/align]
Old 01-09-2008, 09:11 PM
Default RE: ODB II Code 174 only
Which engine do you have? The SOHC 4.0 has had many problems with intake gasket leaks, and sometimes it will only show up on one bank with the lean code.
Old 01-09-2008, 09:48 PM
exp97's Avatar
Yes. That's the engine in my truck. Thanks for the feedback!
metalgear138
02-25-2011 11:11 AM
windystar
11-07-2010 09:34 AM
digital_diversion
01-24-2010 10:12 AM
Bronco76Ranger00
11-08-2009 08:24 PM
ctbob
10-18-2007 08:55 PM
Quick Reply: ODB II Code 174 only
