proper tire pressure
Old 01-25-2007, 02:08 AM
MHartley's Avatar
Default proper tire pressure
Will someone please help me!? Some idiot ripped the label off of my '98 Ford Explorer Sport. Now I have no idea what the right tire pressure is. The manual just says to look at the label. So could someone with a similar vehicle tell me what is right?
Old 01-26-2007, 12:47 AM
wheelsup68's Avatar
Default RE: proper tire pressure
Somewhere btwn 28-32 lbs will be just fine when checking cold.
Old 02-05-2007, 01:05 AM
On my 2002; @ the gas flap, 35 rear,30 front. Why didn't they put a locking function,like on the T Birds. ?
Old 02-25-2007, 01:11 AM
30 rear 30 front on my '01 explorer
Old 04-02-2007, 11:14 AM
Iwork at a shop and you should look at the max tire pressure on the sidewall of the tire. If it says max p.s.i. 35 then set them at 32, if it says max p.s.i. 44, set them at 40. these should be the only two tire pressures on your truck. you could set them at 30 p.s.i. if you want a smooth ride but if you want a longer tread life and better gas milage, i would set them at whatever the sidewall says.
05-02-2012 10:36 AM
boogiesan
06-05-2010 10:40 PM
Autogeek
03-24-2008 10:23 PM
08-09-2005 03:22 PM
08-09-2005 03:22 PM
Quick Reply: proper tire pressure
