Radio display shows CALL
Old 09-20-2008, 10:31 AM
hdandford's Avatar
Default Radio display shows CALL
My 2003 Explorer radio display reads CALL the radio,clock,tape and cd player wont work when this is displayed the message comes and goes.
Old 09-20-2008, 12:15 PM
Default RE: Radio display shows CALL
See if the radio will do/enter the diagnostic self test.. It may give you a 'B' diagnostic trouble code, but would probably require service...
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
[ol][*]To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.[/ol]
[*]To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.[/ol]
[*]If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.[/ol]
[*]The self-diagnostic mode has six manual tests available:
[*]Preset button 1 = ENTER DIAGNOSTICS. This test enters diagnostics from the speaker walk-around test. Metrics are available with SEL and ON buttons indicating time played in AM/FM, media, number of buttons pressed, etc.[/ul]
[*]Preset button 2 = EEPROM BLOCK STATUS. This test shows validity of memory to calibrate clock and seek sensitivity.[/ul]
[*]Preset button 3 = EXIT DIAGNOSTICS.[/ul]
[*]Preset button 4 = Software configuration level. This test queries each radio system controller for its software configuration level.[/ul]
[*]Preset button 5 = DISPLAY TEST. This test lights all the display segments for five seconds and then turns all segments off.[/ul]
[*]Preset button 6 = RAM CONTENTS READOUT. To enter these tests, press preset button 1 while in the speaker walk-around test, then the desired preset button.[/ul][/ol]
[*]To exit the self-diagnostic mode, turn the ignition switch off or the audio unit off.[/ol]
Old 09-20-2008, 01:00 PM
hdandford's Avatar
Not able to peform tests
hdandford
09-29-2008 12:47 PM
hdandford
09-26-2008 11:02 AM
sho_ted
06-03-2008 03:31 PM
77Bronco
05-09-2007 12:51 PM
DonsGarage
05-20-2006 01:10 PM
Quick Reply: Radio display shows CALL
