Rear diff fluid change 2002 Explorer - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 07-26-2009, 09:48 PM
Default Rear diff fluid change 2002 Explorer
I'm planning on changing the rear diff fluid in my 02 Explorer. When I look at the pan it looks like there's a white sealer on the drain plug and a red sealer on the fill plug. Anyone have any idea what type of sealer this is supposed to be and if it's really needed? The shop manual doesn't say anything about sealing the plugs.
Thanks for any help in advance.
Old 08-10-2009, 04:35 AM
When re-installing the plugs, a couple wraps of regular teflon tape will work just fine, then snug the plug. The sealer used by Ford on these just makes installation easier on the assembly line.
Thread Thread Starter Forum Replies Last Post
leak from rear end....possibly rear diff? escaped-eric Ford Escape 3 12-23-2012 02:33 PM
2002 Exp XLT Front diff input seal yowie61 Ford Explorer 0 09-25-2007 07:46 PM
Rear axel / diff/back end 1996 4WD 5Spd sport2 Ford Explorer 3 06-08-2007 11:33 AM
2002 Taurus Transmission Fluid Change mossimo817 Ford Taurus 0 05-10-2006 06:47 PM
Front diff. fluid following seas Ford Explorer 1 11-25-2005 01:57 PM
Tags
1999, 2002, change, crown, diff, differential, drain, explorer, fluid, ford, freestyle, oil, plug, rear, vic
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
