02 f 150 pinion shaft
Old 10-14-2010, 09:17 AM
clarence's Avatar
Default 02 f 150 pinion shaft
working on replacing rear axle seal and when i took the pinion lock bolt out i realized that the end is broke off and still in the shaft so i cant slide it out to push the axle in to get the clip off so i can get the shaft out any one run into this in the past , any ideas
Old 10-14-2010, 04:05 PM
I have used two different procedures and I was lucky each one worked.
One was to tap on the housing to help dislodge the already unstressed broken tip and carefully poke a small pick into the hole while trying to unscrew the remaining piece and then a magnetized small screwdriver to pull it out.
The other was to use a lefthanded drill bit in a drill and slowly work the broken piece out.
There may be other tricks to remove it, lets see what other suggestions other members come up with that might help if the above doesn't work for you.
Old 10-15-2010, 03:06 PM
clarence's Avatar
Default hankey
thanks for the advise. unfortunatly it didnt work that easy. i drilled out the back of the diff pin till i could get in with a pointed die grinder and cleaned it out so i could push the diff pin in and then worked on the locking pin. what an adventure! thanks for the help
Old 10-15-2010, 03:30 PM
Good Job! Are the internal threads in the ring gear housing OK?
ryansteph
03-01-2008 10:20 AM
6663A
07-10-2007 03:21 PM
demomatt
04-24-2007 01:13 AM
jparker82484
07-21-2005 04:11 AM
ODB
05-11-2004 02:45 PM
Quick Reply: 02 f 150 pinion shaft
