1975 f 150 wiring help!
My wiring in my truck is whooped. But trying to make due till I find a parts truck, My dash lights will not work, the bulbs work, but the turn signal arrows still work when I put them on. Nothing on the gauges works either (i.e gas gauge, temp gauge, alt light) was wondering if anyone could help me out. Thanks
I suppose you have checked all the fuses with a test light? You might need to removew the instrument cluster and check the back to see if there is any damage there. If you know the wiring is damaged, you need to repair the wiring before any other repairs are attempted. A little solder and heat shrink tubing goes a long way on wiring repair.
studebaker
01-21-2008 08:08 AM
