1983 Ford F150/ battery draining
I have a 1983 Ford F150 and its draining every battery i put on it, ill put the fully charged battery on in the morning and after a day or two its complety drained. Anyone know what may be causing this? Thank you
A simple way to be sure would be to remove the battery lead from the alternator when the vehicle is not in use and see if the battery still goes dead. You might have to remove the ground cable from the battery in order to safely disconnect the alt lead, protect it from touching any other parts with the terminal end . Reconnect the ground cable and see what happens. you shouldn't try to run the vehicle with the alt lead disconnected unless you remove all the alt wires.
stevemackie
10-07-2012 12:00 PM
