*** braking problem ***
Old 03-14-2009, 11:33 PM
blackharley's Avatar
Default *** braking problem ***
I have a 2001 F-150 (harley edition). When I hit the brakes I have to push the pedal to the floor literally to make it stop. The front brakes were done 6 months ago, the rears have good meat on them and the power brake booster is working fine. The master cylinder is not leaking and the fluid level is more than half full. I can not begin to think where the problem is in this truck. Anyone have ANY IDEAS??? Let me know, Thanks, Black Harley
Old 03-15-2009, 07:09 PM
Bullitt94's Avatar
It is possible that there is a crack, hole, etc. in the system somewhere. Does the system build pressure rapidly if you pump the pedal, or does it take a while? Have you pumped the brakes while parked to see if any fliud leaks out?
If no fluid leaks out, I'd start by filling the brake fluid reservoir and bleed all the brakes. Watch the fliud level for a few days and see if it goes down.
Old 03-17-2009, 10:36 AM
carparts.abhi's Avatar
I also think that there is crack or hole somewhere.
Old 03-17-2009, 08:49 PM
JTGrant1's Avatar
I don't... I think that if there isn't any fluid coming out, it is possibly air still in the system but i think that it seems more like a problem in the master cylinder. It will have that low pedal/ spongy feel if one of the seals on one of the pistons is bad. it is most likely the one farthest away from the firewall because if it were the closer one there would be fluid on it, or in the cab...
KeithSchedlosky
01-16-2011 06:14 AM
joemahn
07-08-2006 11:23 AM
fasttalker
11-30-2005 09:32 AM
jk16201
09-13-2005 04:04 AM
FordFan5
08-11-2005 06:14 PM
Quick Reply: *** braking problem ***
