1993 F150 Ignition Switch Replacement
Old 06-28-2010, 04:33 PM
outdoornut42's Avatar
Default 1993 F150 Ignition Switch Replacement
How hard is it to replace switch and does steering wheel have to be removed to replace turn signal/wiper delay switch? Thanks!
Old 06-28-2010, 07:15 PM
way2old's Avatar
It is easily replaced. The steering wheel does not have to come off. If it has tilt, remove the tilt lever. Then remove 3 screws under the lower steering column cover. Threr are 2 little torx headed screws that hold the switch in place. Remove the screws, unplug wiring and replace switch.
Old 06-29-2010, 01:51 PM
Is the ignition switch easy to replace, I've been told just to move switch to run position and use small drill bit in hole under ignition switch (shroud) to release pin that holds in ignition switch and switch pops out?
Old 06-29-2010, 07:32 PM
way2old's Avatar
If you are talking about the key cylinder, you have the correct procedure.
Old 06-30-2010, 04:09 PM
Thank you for your help!
RickE33
03-02-2014 04:55 PM
pappapat
11-13-2013 02:37 PM
luigi87
09-10-2013 11:40 PM
BustedVan
08-02-2013 05:33 PM
Downhill Stan
12-30-2009 06:34 AM
Quick Reply: 1993 F150 Ignition Switch Replacement
