1997 f150 4x4 shifter stuck in neutral or 4 hi. Won't disengage
My truck wasn't running (dead battery). I needed to move it out of the street so i turned the key to accessory mode and put it in to neutral ( 90% positive i put it there) then i moved the 4x4 shifter to i think 4hi or N option. I changed the battery not to long afterwards then started it after the battery was changed and went to put it in reverse and i heard a heavy grinding noise of the gears and i tried to change the 4x4 shifter to 2 hi and it won't move or disengage. PLEASE HELP
1992explorer4x4
01-10-2007 05:00 PM
