Sponsored by:
Sponsored by:
1999 F-150 wont shift
Old 03-24-2013, 08:06 PM
BAleroS's Avatar
Default 1999 F-150 wont shift
Did I little searching on here, but couldn't find the answer I wanted. So here's the scoop.
My 97' F-150 does not like to shift out of park, after checking some things, the brake lights work at various levels of peddle pressure, and as most of you know, if the brake lamps are not on, the vehicle will not shift. This started about a week ago and I don't have any problems driving it, but sometimes it takes a while to find a pressure on the brake peddle that works to shift.
So I am just wondering is there a fix for this, and what is the issue? Fuses are good. Is there a sensor for the brake that's not getting a good connection or voltage?
Old 03-25-2013, 09:31 AM
grindman's Avatar
I think that there was a recall on those something to do with a fuse or something like that on the master cylinder. and the brake light switch may or may not be sticking you might want to replace the switch and see if that doesn't do the trick.
BAleroS
03-26-2013 04:47 PM
gregorys81
12-13-2012 01:54 PM
silverT1000
05-03-2007 12:51 PM
93f250xlt4x4
11-05-2006 05:42 PM
dilligaf58
09-12-2006 07:57 PM
Quick Reply: 1999 F-150 wont shift
