2007 F150 4 Wheel Drive Engaging
Old 12-15-2014, 08:43 PM
ylolablvr's Avatar
Default 2007 F150 4 Wheel Drive Engaging
I have a 2007 F150 Crew Cab with electronic four wheel drive sometimes when I am driving the four wheel drive tries to engage which makes a horrible grinding and loud noise. If I slow down or put it into four wheel drive high it will engage and quit. I have jacked it up on the lift and checked the front end, transmission and transfer case levels and they were all ok. Any one else ever have this issue?
Old 12-15-2014, 11:42 PM
Use Common Sense's Avatar
I haven't worked on the newer 4x4 hubs. but they are vacuum operated and are prone to vacuum leaks at the vacuum valve that I believe is located under the battery. Check that for a leak(s).
Nichole Johnson
06-30-2014 07:14 PM
farmerbrown
11-18-2013 05:17 PM
Harburmaster
02-16-2009 09:12 PM
broncky
10-08-2007 07:59 PM
broncky
10-08-2007 07:59 PM
Quick Reply: 2007 F150 4 Wheel Drive Engaging
