1992 f150 4x4 shift tube / AOD trans
Old 03-09-2011, 11:56 PM
toykle's Avatar
Default 1992 f150 4x4 shift tube / AOD trans
Recently, reverse has been kind of sporadic. Seems better when cold. Yesterday, shift tube appears to have broken.
Just wondering if there's the slightest possibility that a failing shift tube could have been causing the problems with reverse.
Still needs ball joints, upper and lower, and finances are literally non-existant.
Am I nuts to keep throwing money at the old girl?
She plows great and just got the plow rebuilt, extra-heavy alternator, new brake lines, etc. Can't afford a new one, so I at least know what this one needs.
Sounds like the shift tube is something I can do, but should I?
Any input would be appreciated!
Old 03-11-2011, 12:13 AM
toykle's Avatar
Update
Replaced the shift tube today. Easier than expected.
Can't get it into reverse or park without lots of fiddling. (No worse than before shift tube and plunger broke into 5 or 6 pieces. lol)
Isn't there some way to adjust the linkage?
Or maybe it's something with the cable?
Help please... Input would be greatly appreciated!
Thanks
Old 03-11-2011, 08:17 AM
Bullitt94's Avatar
If you follow the linkage down to where it goes into the tranny there is a little plastic piece over the linkage that pops into a link that is on the tranny. That plastic piece wears out and can make it tough to get into the proper selected gear. Give that a look if you haven't already.
Old 03-11-2011, 10:44 AM
toykle's Avatar
Will check that out asap! Probably later this afternoon.
Thanks a million. Your help is greatly appreciated.
I'll post back with the outcome.
Dakota_Don
05-12-2010 02:44 PM
xp coupe
04-16-2008 06:21 AM
chopdrop
03-12-2007 06:47 PM
65chero
10-08-2006 01:32 AM
Eco E150 1992 302 V8
08-14-2006 05:36 PM
Quick Reply: 1992 f150 4x4 shift tube / AOD trans
