4x4 problems when turning
Old 02-15-2010, 11:14 PM
caseih1460's Avatar
Default 4x4 problems when turning
Recently my 2001 F150 4x4 has been very hard to turn when the 4x4 is engaged. Does anyone have an idea as to what may be causing this problem. Thank you...
Old 02-16-2010, 09:57 AM
Bullitt94's Avatar
Does it only get hard to turn when in 4WD?
U-joint(s) in your front axle shaft(s) may need to be replaced. Might be causing a little bit of binding when you turn if they are going bad.
Old 02-17-2010, 08:21 AM
Bullitt94's Avatar
Should also note that depending on the type of surface you are driving on it may seem harder to steer with 4WD on. If you are on harder, drier surfaces it will seem more difficult. If that is the case, you shouldn't be using 4WD in that situation as it can wear on the truck.
fl_hayseed
06-24-2009 08:33 PM
sprdty21921
02-27-2008 02:06 PM
dws13060
07-28-2007 11:53 PM
linkschamp
06-16-2007 10:30 AM
steveburton
01-19-2006 01:06 AM
Quick Reply: 4x4 problems when turning
