86 f-150 problem
#13
.........replaced the fuel relay on the driverside firewall also the coil still having same problem going with replacing the cheaper parts far as cost both pieces were 20-30 each next will be the module on the distributor if that doesn't work gonna try the fuel pump assembly replaced both fuel filters already
#14
If/when you replace the TFI module on the distributor, ensure that you clean the mating surface off real good of the old heat sink compound. Then put a light coating of new heat sink compound on both the distributor and TFI module mating surfaces before installing. The bolts for the TFI module require a thin walled socket to remove them.
#15
Common
#16
