Sponsored by:
Sponsored by:
leaking fuel under hood
Old 11-21-2007, 10:16 AM
jerneug's Avatar
Default leaking fuel under hood
I have a 97 f150 and have had a rat/squirrel get under hood and chewed fuel line. Is this easy to replace? can you patch the line?
Old 11-28-2007, 08:38 PM
greuelc's Avatar
Default RE: leaking fuel under hood
if it is a steel then you should be able to cut the bad part out and usingnew steel line andcouplers to rejoin it together.
Old 11-29-2007, 11:53 AM
oldtimer35's Avatar
Rat chewed your fuel line? I thought all the fuel lines were metal. Are you sure you don't have a fuel pressure regulator leaking? What engine do you have and where bouts is the leak coming from?
tvtom
01-09-2008 09:09 PM
tvtom
01-09-2008 09:09 PM
biggie97
01-25-2007 03:51 PM
azr racing
01-22-2007 12:48 AM
Quick Reply: leaking fuel under hood
