91 f-150 5 speed ,driveabilty (jerks & rough idle)
The problem is when truck idles @ (or about) 700 Rpm has a miss on cyl.2 ( taking plug wire or injector plug off no change ) , bring up rpms to 1000 it smooth out , & while driving at (or about) 45 mph in 4th it will jerk ( like 1 time ) then go back to smooth . New wires ,plugs , cap ,rotors button ,fuel filter. Any help will be appreciated & thanks for ur time
you may want to get a pressure test done.. it could be a ring or a valve leaking.. At low RPM's it will run rough.. if you pull the plug wire off at a higher rpm do you see a change? if so have the test done or pick up a tester for $50 and do it your self.
rough idle
Did the compression test ,went as follows : #1 - 145,#2 100,#3-150,#4-150 , #5-150 and #6 didn't do due to plug ( felt like it was cross threaded so left it alone) . Not sure what else to do, any ideas? thanks for your time
Soar1000us
02-07-2010 12:12 PM
