'97 F150 Backup Lights not working
RE: '97 F150 Backup Lights not working
The Digital Transmission Range sensor (DTR) controls current flow when 'R' is selected for the back up lamps.. Be sure to check fuse position 5, 15amp fuse.. Here is a pic of the DTR.. It mounts to the side of the trans where the shift cable/arm connect..
[IMG]local://upfiles/6756/3E58CE3CC9C8441D929E38DD459E722F.gif[/IMG]
What engine do you have, and whats the build date of the truck? I can give you the connector configuration/wire colors to check/probe for DTR function for the back up lights to verify/diagnose the switch prior to replacement..
cu101man
02-01-2010 11:35 AM
no1toolman36
10-23-2009 10:13 AM
caper74
04-25-2008 01:11 AM
