Bigger tires for F-150?
Old 08-22-2015, 06:55 PM
Alexalise's Avatar
Question Bigger tires for F-150?
Hey, I just purchased a 1995 F-150 and it has 235/75R15 tires. I'm entertaining the idea of putting larger tires on it, but want to fully understand the results I would get if I do so.
I've been told that my Speedometer might go out if i do. And that I need to check if the truck will be able to handle a larger tires size.
Advice?
Old 08-24-2015, 08:03 PM
primem's Avatar
don't know how the speedometer would go out....the speedo cable would turn slower and be inaccurate... so how would that hurt anything?
Old 08-24-2015, 11:16 PM
Use Common Sense's Avatar
When looking at using a larger tire, you need to ensure that the new rims will fit around the brake calipers. Then you need to look at the offset of the rim to ensure that the new tire stays centered in the wheel well to ensure equal clearance. Also, depending on how large you go, you also need to verify turning clearance within the wheel well.
As far as you speedometer goes, "Primem" is correct. The larger you go, the slower your speedometer will read. I run the largest tire you can fit on a Freestar and my speedometer reads 5% slower than actual speed.
astrapous
12-22-2008 10:13 PM
BLutzeier
12-08-2007 04:50 PM
jasper
02-22-2007 11:49 PM
rykno44
08-06-2006 11:33 PM
l00py1211
10-19-2005 04:56 AM
Quick Reply: Bigger tires for F-150?
