Sponsored by:
Sponsored by:
Overheating Problem
Old 06-11-2009, 12:41 PM
jeffandteneka's Avatar
Default Overheating Problem
I have an '03 F-150. Yesterday it overheated within 2 miles from my home. Parked it immediately. Never saw any visible signs of water leaks (hoses/coonections). Changed the thermostat and drove about 10 miles without any signs of overheating. Got in this morning and within 5 miles it overheated again. Parked immediately. Water pump???? or other issue?
Old 06-11-2009, 12:55 PM
Bullitt94's Avatar
Is there fluid in the overflow?
If not, there is more than likely a leak somewhere. It may be small, but it is somewhere. Add fluid to the overflow/radiator and run it for a while to see if you can find the leak.
Old 06-23-2009, 12:36 AM
budro's Avatar
when you changed the thermo you may have let air in the system
askedofgod
07-18-2015 11:53 AM
kicolvin55
07-13-2011 06:00 PM
chasityhall4
06-16-2007 06:58 PM
MXDAD503
11-10-2006 08:33 PM
Road_Rage_
06-27-2006 01:53 AM
Quick Reply: Overheating Problem
