Sponsored by:
Sponsored by:
problems with truck running
Old 06-13-2009, 03:50 PM
mustangmitch2010's Avatar
Default problems with truck running
i have a 1980 ford f150 ranger with a 351M. when i start it up it sometimes will idle sometimes it wont and then when i start to drive it i will get up to about 35 45 mph and then it starts to cut out and dies on me even when i give it gas......i have rebuilt the carb but on new spark plugs and spark plug wires, ignition coil, mechanical fuel pump, and a new rotor inside the distributor, and new distributor cap.....gimmie some ideas on how to fix it
Old 06-15-2009, 01:09 PM
oldtimer35's Avatar
Is the egr valve opening up prematurely? Or is it already stuck open? You can tap on the base of the egr with the engine idling and see if the idle improves. You might have carbon stuck in the port on the valve.
Old 06-19-2009, 06:33 PM
i figured it out i had a push rod that fell down into my engine on my third piston
Dawggtired
05-28-2014 03:06 PM
iuecbrad
11-01-2011 10:06 PM
wheelzzs
01-09-2010 10:09 AM
babygirl111
06-27-2008 07:15 AM
96F350Panel
11-27-2007 02:59 PM
Quick Reply: problems with truck running
