Sponsored by:
Sponsored by:
HELP?? 4.6
Old 08-28-2008, 07:43 PM
97fordman08's Avatar
Default HELP?? 4.6
Hey guys! New To the site and Im sure there is a thread for this But I couldnt Find one!!
I have a 97 Ford F150 4x4 with 4.6 v8
Engine light came on and started flashing I hooked it up at autozone on a scan tool and it says Bad EGR Valve and Missfire Detected in Cylinder # 4
So I change The Plug (Which by the way is a pain to do) No change Still Missfire and Shakes like it has a tire out of balance goin down the road! So I check The injector with an ohm meter and All The injectors are The same.. I know it still could be a bad injector but for now Im Runnin Some injector cleaner through it! Im Going Tomorrow To get the compression checked.. Hopefully Nothing Major but with my luck It probably is ! Has anyone had this problem? COuld it be something else minor??
[IMG]local://upfiles/17700/9598C8157608493093D78E750F7070FF.jpg[/IMG]
jd637
02-22-2019 08:14 AM
jborushko
12-22-2016 08:06 PM
Quick Reply: HELP?? 4.6
