engine problem
What year is it? this info is important.....Do you have check engine light flashing?
start with the basics......Pull the dipstick and check fluid. Does it smell or look discolored? normal fluid is bright red like strawberry syrup and has a slight petroleum smell.
If fluid is dark or smells burnt..this is bad...it probably means overhaul but not always.....
If fluid is in good shape then there is hope....drop the pan and look for particles in the pan larger then grains of salt....if no particles then perhaps you have solenoid or servo issues...or speed sensor issues if it a late model transmission..
jamesmanning
11-03-2010 10:49 AM
