F150 4X4 Inoperative and Noisey
Old 02-02-2014, 03:18 PM
makuloco2000's Avatar
Default F150 4X4 Inoperative and Noisey
These are starting to creep up again with the cold wet weather and of course when you need it most your 4x4 doesn't work. It all starts with the vacuum solenoid up on the firewall and goes downhill from there. Even if you don't have this issue yet I explain why you should change the solenoid and save yourself from a costly vacuum hub replacement down the road. I also show you how to replace the vacuum hub (IWE) if yours is already damaged.
makuloco2000
11-07-2014 04:04 AM
makuloco2000
02-02-2014 06:56 PM
makuloco2000
09-19-2013 11:12 PM
jfed1020
07-07-2012 02:08 PM
acit_marcl
12-16-2006 07:03 PM
Quick Reply: F150 4X4 Inoperative and Noisey
