f150 both fuel pumps keep running
They usually run for a second or 2 and shut off and the truck will start. Today I turned the key on and either pump will just keep running and it wont start. Changed the fuel filter but it was super easy to blow thru so I don't think that is it. Where should I look. Thanks. I have trouble walking and now I have nothing to drive
There are so many things electrically controlled in vehicles today. The first and usually easiest thing to check is , all the fuses. You have fuse blocks in the engine compartment and inside the vehicle. If you have the owners manual it may save you some time by telling you what each fuse controls. Lets try this first, OK?
pilleway
03-09-2011 07:49 AM
