F150 ENGINE RUNNING ROUGH
Old 12-16-2005, 03:58 PM
rrmojica's Avatar
Default F150 ENGINE RUNNING ROUGH
I have an 02 Ford F150 and it started to run rough between 30-60 mph. When I say rough I mean like you were on a chisel plowed field. As of this morning it is running rough at an idle and during acceleration, with no check engine light. I checked the cats and they are fine, any suggestions would help.
Old 12-16-2005, 04:24 PM
frdtek05's Avatar
Default RE: F150 ENGINE RUNNING ROUGH
In most cases of running rough on the 4.6 and 5.4 a bad coil will give you those symptoms. When it's idling rough, unplug each of the ignition coils 1 by 1 and take note of the one that makes the least difference in idle. When you've found the misfiring cylinder, pull the coil and check the boot for signs of water contamination. Most commonly, #4 cylinder will have water/coolant contamination due to the heater hose connection above it leaking.
If the coil boot and spark plug hole is dry, swap that coil with one next to it and re-do the test I mentioned above. If it's the coil, the misfire will transfer over to the other cylinder.
Good luck
Old 12-17-2005, 02:24 AM
rrmojica's Avatar
Thank you, you were exactly correct. It was the number 4 cylinder, I replaced the coil and the truck is running perfect.
Thank you again
Warren Hart
06-10-2013 03:23 PM
trakker
10-10-2011 06:12 PM
ccsuhoops
09-04-2011 11:06 AM
wick
06-29-2008 04:12 PM
GiiDarwin
08-01-2004 06:09 PM
Quick Reply: F150 ENGINE RUNNING ROUGH
