Sponsored by:
Sponsored by:
F150 Issues
Old 06-22-2014, 05:01 PM
Ron Newson's Avatar
Default F150 Issues
I have a 07 f150 and low oil pressure and probably has caused my vct cam to make my check engine light come. If I replace vct cam would this fix my problem.
Old 06-22-2014, 05:04 PM
You should find and correct the cause for the low oil pressure first.
Old 06-23-2014, 07:38 AM
Ron Newson's Avatar
Default f150 issues
Should change the oil pump. then work my way to the solenoids then vct cam
Old 06-23-2014, 05:22 PM
Which engine is in your 150 ?
Old 06-24-2014, 06:01 AM
Ron Newson's Avatar
Default f150 issues
5.4 triton
lariat
Old 06-24-2014, 02:14 PM
A wise move would be to confirm the actual oil pressure with a mechanical gauge both cold and hot , unless you have already done that.
dwarber
11-04-2009 12:12 PM
yar89
04-22-2008 12:00 PM
LittleGreen
03-07-2008 08:03 PM
LittleGreen
03-06-2008 07:12 PM
hitkrdnck62571
09-21-2006 11:04 PM
Quick Reply: F150 Issues
