F150 radio display
Floor shift uses a LED panel..
Ford always uses a LB/RD wire color/tracer for panel illuminations. If it were a fuse or power distribution problem, there would be a 'bunch' of control illumination issues since they share a illumination circuit splice, cluster , message center etc. Did both issues happen at the same time? or, one then the other over time?
You could pop the shifter bezel up and use a test light and check for 12v on the LB/RD wire coming in to the shifter connector. If you have power there, the LED is failed. As well as the audio unit, same wire color config. With the radio ON, is there any display?
