Sponsored by:
Sponsored by:
F150 radio display
Old 01-13-2015, 08:20 PM
michaelmchale271's Avatar
Default F150 radio display
My radio works fine but the light display will not light up. Nor will the shifter. Any help?
Thanks,
Michael
2006 F150
Old 01-16-2015, 12:23 PM
Not sure what your vehicle has, but there are some that use a lamp to provide a source of light that is transferred via a flexible fiber optic cable to a remote location(s).
Old 01-17-2015, 06:20 AM
Thanks for the reply. How would I be able to find out if mine has the FO cable? Is it a easy fix?
Old 01-17-2015, 10:19 AM
Post
Floor shift uses a LED panel..
Ford always uses a LB/RD wire color/tracer for panel illuminations. If it were a fuse or power distribution problem, there would be a 'bunch' of control illumination issues since they share a illumination circuit splice, cluster , message center etc. Did both issues happen at the same time? or, one then the other over time?
You could pop the shifter bezel up and use a test light and check for 12v on the LB/RD wire coming in to the shifter connector. If you have power there, the LED is failed. As well as the audio unit, same wire color config. With the radio ON, is there any display?
Old 07-28-2015, 01:13 PM
Put this on the back burner for awhile. No, no display while the radio is on. No time display when the radio is off or on.
Rick76
10-22-2012 05:35 AM
hdandford
09-20-2008 01:00 PM
fordstang
03-21-2008 11:31 AM
bill9iron
05-25-2007 04:25 PM
RTC23
02-21-2007 09:08 PM
Quick Reply: F150 radio display
