ford f150
F150 Stalling
A little more detailed information would be helpful to all who read this post, but torque converter clutch solenoid is what comes to my mind, i believe you can somewhat test it by lightly hitting the brake while holding the gas when driving, the rpm should spike up a small amount momentarily, watch your tach while doing this. If not i would start looking at the torque converter clutch in the transmission. Im sure other would have suggestions you might try also.
Another thing to try, but won't PROVE anything if clutch solenoid is INTERMITTENT. If the clutch is stuck engaged, that is, not DISENGAGING, shifting to neutral while coasting to a stop, at maybe 10 mph, will "prove out" stuck clutch: engine will remain idling in neutral. Then, a shift into "D" will stall it. imp
