Humming sound from engine.
Old 01-28-2014, 11:28 AM
saintfan's Avatar
Default Humming sound from engine.
I keep hearing an intermitten humming sound from the engine. It comes and goes. Any idea what is causing this? 2003 F-150 4.6 Litre engine.
Old 01-28-2014, 05:51 PM
First thought that comes to mind is possible idler pulley bearing. Sometimes a vacuum leak not big enough to cause serious engine problems can make some crazy sounds also.
It would help if you could tell us if it is coming from the front, which side, or rear of the engine. If you remove the serp belt and spin each pulley the belt drives could possibly help determine if one of them is becoming borderline on failure. You would look for looseness or noise/roughness when turning the pulley.
Old 01-29-2014, 10:45 AM
saintfan's Avatar
Thanks Hanky I'll take a look at the pulleys. I've heard that maybe air passing over the intake may cause something similar and also the Idle control valve. Do either of these sound plausible to you? And if it's air passing over the intake-what can be done about this?
Old 01-29-2014, 02:09 PM
There have been times when the air filter assy was not completely assembled and it would make weird noises.
ralph50
10-21-2023 09:42 AM
rvgliberty
03-27-2006 11:45 AM
joshua.donelson
09-27-2005 08:03 AM
jchap
09-26-2005 06:51 PM
TexFordOwner
06-16-2005 01:32 PM
Quick Reply: Humming sound from engine.
