Steering column names
After disconnecting the battery for 15/30 minutes you would need to start at the top of the steering wheel , remove horn air bag pad , with special puller remove steering wheel and work your way down to the ign tumbler.
This is not the kind of job you would want to get involved in if you don't have the right tools and some experience. It is a somewhat lengthy job and a lot of shops will swap out the whole top section because of the time involved. You might want to check u-tube for a video showing what is involved.
Fordo
07-19-2012 06:28 PM
mystarcollectorcar
11-06-2010 05:18 PM
