steering Help
I believe that you have a rack and pinion assembly. I would look to see if you have any U-Joints on your steering shaft that connects to the rack. If any are exposed, the u-joints may be seized. Even if not exposed, they could be dry. I had that issue on my Freestar where it all of a sudden would not return to center and the steering was stiff. I sprayed the steering shaft u-joint (was exposed) with some WD-40 and it loosened right up like normal, but returned to stiff a couple of days latter. Replaced the steering shaft and all has been good for years.
Fordo
07-19-2012 06:28 PM
jaymzsun
03-10-2011 08:13 PM
