Sponsored by:
Sponsored by:
swap 300 six to 302
Old 12-20-2005, 11:23 AM
BigMuddy's Avatar
Default swap 300 six to 302
I have a 91 f-150 with a 302 that is EFI, I want to switch it to carberated and put it in my 78 F-150/ F-series truck. I need to know if a 302 will bolt up to the 4 speed that the 300 is bolted to, if not can the bellhousing be switched out, or is there an adapter plate that i can get. Also if i use the 302 and switch it to carberated will i need the computer from the 91 or can i do with out it. Also any other suggestions would be helpful thanks. Also the 91 is automatic and the 300 is standard. Will i need to replace clutch and pressure plate and throw out bearing because i just put them in new before the 300 blew.
coupe33
07-06-2011 09:50 PM
SuperHighOutput
10-02-2007 05:19 PM
jhenessee
09-19-2007 08:40 PM
bnokle
12-14-2005 02:32 AM
semperfi48103
08-30-2004 02:28 AM
Quick Reply: swap 300 six to 302
